NEED HELP!!!
so i was ridin the other day, and my gauge lights went out, for the mph and tach, so a couple days later, i'm riding my bike and the bitch dies, start it back up then rode it, when i romped on it, it wasn't goin anywhere fast, soon after it died after having to push start it 5 times, i got it home, then i rode it the next day for about half hour, everything was fine, then it dies, so i put a new batt in it, ride it for prolly 30minutes to an hour, dies again!!!!!! so i know that something is draining the battery, its not re-charging, ive read that basically any light out, is bad and can short and cause a draw, could it be my gauge lights???????? i need some help, i'm gettin pissed, and i don't kno how the charging system on a motorcycle works, so someone please help
Take of your seat and using a voltmeter, put the positive clamp on the positive and negative on the negative and start it up..it should be producing @ 13.5V or so at 5000 RPM, if it is not then you probally have a charging system failure, more than likely the regulator/rectifier
its gotta be that, i don't kno how the charging system on a bike works, but i fired it up after 3 or 4 days, and fired right up, its just once the battery dies, its done, it doesn't get charged, is the regulator the only possibility?
