Mods
Old Jan 27, 2007 | 04:35 AM
ThisisMickey's Avatar
Default Mods
Hey guys I was just thinking about mods i would like to do, and at the top of my list is fender eliminator. But it is also the most confusing to me. could somone shed some light on this subject for me. And if anyone has any mod ideas I am looking to make my bike customized for me.
Old Jan 28, 2007 | 10:53 PM
kiwicbr's Avatar
Default RE: Mods
Easiest and cheapest way is to cut your exisiting fender down with asharp blade (stanley knife) andbolt ona universal 'rrsend' plate bracket and indicators.
http://www.sportsbikeshop.co.uk/moto...nt_prod/30/426
I did this recently and takes no time to do.
Old Jan 28, 2007 | 11:37 PM
Bobthebiker's Avatar
Default RE: Mods
on mine, the fender is totally gone in the first place, so I used a bit of 1/8"x3/4" aluminum stock bolted to the subframe, and holding the tail light plus tag.
Old Jan 29, 2007 | 02:56 AM
bindelsf2's Avatar
Default RE: Mods
this is what i did. i made it myself and it tucks the plate way under the tail. cost about 6.00 to make
http://i88.photobucket.com/albums/k1...7/100_0354.jpg
http://i88.photobucket.com/albums/k1...7/100_0332.jpg
Old Jan 29, 2007 | 03:11 AM
Default RE: Mods
That look good bindelsf, thanks for the pics. So ya I think I will just cut it if that is an acceptable solution. But the previous owner took off the mud gaurd/chain gaurd on the back tire. Should i Buy a new one before I start cutting my current fender? And I am just worried I will buy something I cant use, does this look like a decent item to buy? And can a novice figure out how to get new turn signals connected? http://cgi.ebay.com/ebaymotors/97-98...spagenameZWDVW
Old Jan 29, 2007 | 03:19 AM
Default RE: Mods
And on a seperate note, I have some frame sliders I just got from ebay, but I dont know how i am going to make an accurate hole in my fenders and suggestions?
Old Jan 29, 2007 | 03:31 AM
bindelsf2's Avatar
Default RE: Mods
that looks like a good kit. i dont know i havent seen it before..
for the sliders heres a easy easy way to do it:
1. take fairing off.
2. back out the bolt where the slider is going to go far enough to just touch the fairing
3. put play-do on the fairing and reattach
4. take the fairing off
5. tape the painted side of the fairing so you dont chip the paint
6. drill a small hole through the middle of the bolt head mark in the play-do
7. take a hole saw and drill the hole from the painted sided though the fairing.
8. remove the tape and you should be good to go..
heres a pic of mine. i got the extended sliders too..hope it helps.. you cant see them that great but it shows.
http://i88.photobucket.com/albums/k1...amera_0111.jpg
http://i88.photobucket.com/albums/k1...amera_0107.jpg
Old Jan 29, 2007 | 04:53 AM
kiwicbr's Avatar
Default RE: Mods
Also if you cut the rear down rather than remove it, you still get to keep the little cubby hold which is sometimes useful and keeps the **** off the rear of the seat.
Here's a closeup of mine.....
[IMG]local://upfiles/12762/96F5ADDFA2774DB3910CF094A436BCCA.jpg[/IMG]
Old Jan 29, 2007 | 07:00 PM
Funedude05's Avatar
Default RE: Mods
I'm not sure what all has been done to your bike already, so this is just an idea. You can mount your tag to the plastic tab right behind your battery compartment.I'm pretty sure theplastic piece is attached to the seat. I did it on my '94 F2a little bit before it got stolen.Since i don't have it in front of me i can't really take pics pr describe in great detail.it was pretty far under there, but it clearanced the tire and was still visible from the rear. The tab was about 2-3 inches long (hanging down) and was just wide enough to mount the tag with about 1/2" on each side. If you have any of the stock fender, the tag may not be visible if you put it there, but it's just an idea. Hope it helps!
Old Jan 30, 2007 | 12:28 AM
Default RE: Mods
Thanks for all the input guys appreciate it
