Missing one little thing....
That is the reason I stopped messing with it. I knew if I did, I was bound do damage something. When you say take off the head, do you mean the cylinder head? I thought I'd have to pull the whole engine or something to get it to a shop.
EDIT: I just looked up cylinder head removal in the manual. I'd be WAY in over my head. I feel as if I am already...
Is there another place I could put it other than the hose that goes from petcock to the carbs?
EDIT: I guess I could put it right after the hose pictured goes into the carb hose. As in, right between this hose and the carb hose. The one that comes from carbs and becomes just one hose.
OK I apologize in advance for the below if it is from a brain fart due to you panicking about the bolt. Otherwise step away from the tools, and i have no idea how you got the valve cover off.
Have you ever drilled metal before? Do you know what a center punch is? Dont get shavings on your engine, you should know a couple of tricks to do this.![Icon Roflmao](https://cbrforum.com/forum/images/smilies/icon_roflmao.gif)
https://en.wikipedia.org/wiki/File_%28tool%29
Flat is the flat rectangular one, second one down.
https://en.wikipedia.org/wiki/File:MachineFiles.jpg
1![Icon Slap](https://cbrforum.com/forum/images/smilies/icon_slap.gif)
2 Makes 1 acceptable if it was a brain fart due to it being recessed...
