Missing one little thing....
Old Jan 25, 2013 | 10:08 AM
Hyena's Avatar
Default Missing one little thing....
How bad of an idea would it be to ride with a missing valve cover bolt? I ask because one of the bolts was broken off into the block. I've tried for hours to get it out and have had no success.
Old Jan 25, 2013 | 07:41 PM
MadHattr059's Avatar
Short term you might get by.
Long term, I would be concerned with the cover warping, at sustained,
high-temp riding. It might make a difference where in the pattern, the broken bolt is.
Hopefully, Demon, Conrice, IDoDirt, or one of the other gurus,
can give a more definitive answer.
Personally, I wouldn't take the chance. If it were my bike, I'd drill it.
Start with a small bit, to get a good indexed square hole in the bolt.
Gradually increase the size, till you're almost removing threads.
Use an extractor to back out what's left.
Re-tap the hole, with a blind/bottom tap, to clean the threads.
Use grease with the tap!! Clean up with solvent, finally blow it out with compressed air.
Then, re-install the cover with the replacement bolt.
If you take your time, it's not a particularly, difficult task.
Hope this helps, Ern
Old Jan 25, 2013 | 10:17 PM
Hyena's Avatar
Thank you for the reply! I've tried drilling but can't get to bite. Broken piece has rounded head. Drill bit walks ALL over.
I just need it to ride to the stealership so I can have them deal with the problem.
Old Jan 25, 2013 | 10:36 PM
74demon's Avatar
Do you have enough sticking out to get vise grips on it?
Otherwise, to drill it you will need to file a flat surface to drill on. Then center punch a spot in the center to help the bit stay centered. Start small and go slow until you get to the correct size for a screw extractor.
If an extractor doesn't do it, keep drilling until you get all the bolt out and run a tap to clean up the threads or keep going a little bigger and install a helicoil.
Old Jan 25, 2013 | 10:48 PM
Hyena's Avatar
Unfortunately, not out enough for vise grips. How would I go about filing a flat surface?
Old Jan 25, 2013 | 10:50 PM
74demon's Avatar
Use a flat file and file the top until its flat enough so you can punch a center mark.
Where is the broken bolt located? Center or corner? If its a center, I'd run without it and see if it leaks or not.
Old Jan 25, 2013 | 10:52 PM
Hyena's Avatar
This is probably a dumb question, but where would I be able to buy a flat file? Would I be able to file it no problem even though it's recessed?
Old Jan 25, 2013 | 10:55 PM
74demon's Avatar
Flat files can be bought a Home depot.
Recessed? I thought you said some of it was sticking out. My bad.
Picture time!
Old Jan 25, 2013 | 11:07 PM
Hyena's Avatar
Here it is!
Old Jan 25, 2013 | 11:24 PM
74demon's Avatar
Punch a good center mark and see if you can get the bit to stay in the center.
Otherwise, you may need to remove the head and see if a machine shop can get it out. If you damage the area around the hole too much, the head will be ruined.
