Lowering question
My girlfriend has a '94 f2 and is VERY short. I lowered it 1" in the rear using one of those lowering links with the 1" and 3" settings that is all over fleabay. Unfortunately the lower of the 2 settings will not work. I have a shock from a '98 f3 that I tried to use in conjunction with the link because I heard that would bring it down another inch but it didn't. It actually raised it back to nearly stock height. I have the preload set as low as I can and I have shaved the seat and she still can't touch the ground very well. She can reach and is able to ride but it would help a lot if I could get the rear down a little more.
Anyway, my question is, does anyone know of a lowering link that will lower the rear 2 inches and where I can get one? I'm looking for an answer from someone that knows for sure. The advertising forlink I have now claims that you can use the 3" setting but you cannot.
Thanks
Thanks
[:@]this is one of those cases where I whish I knew where the link to my bike came from, my bike's seat is in the 28-29" height. If I understood correctlyu said ur usinga shock that doesn't belong to that bike? what bout the original?? ...hope u find something...
Have you tried lowering the front at all too? If you just loosen the triple clamps you can slide the forks up a couple inches, that would probably help with the height, as well as being closer to stock geometry relative to the lowered rear. If that doesn't work I'd be looking for a ninja 500/250.
Yes, I have the front down about 1 3/4". I have room to go a little more but the front alone doesn't change the seat height much. I realy need to get the rear down an additional 1/2-1" (total drop: 1 1/2-2") There's really no need to change bikes, as she can (and does) ride this one. It would just be better if she could touch a little more solid.
This is the lowering link i have on my bike and both heights work on mine. Why doesn't yours work, is there somthing in the way? Does it hit? Little more info would be helpful.
I don't have it on now, I took it off because i scraped whenever I would hit the twists a little too hard. tore up the bottoms of my lower fairings. I just used it when drag racing after that.
Mine looks just like that one, I don't have it on the lowest setting but I just went and looked at it and I don't think it would go there on mine either, the shock would hit the pivot bracket before it would line up with the lower hole. If you relieve (notch) thepivot a little bit, it might go, but you also need room for compression. Obviously, if you notch it, you will remove a bit of strength, but that looks to be a pretty stout piece anyway. I think the footnotes on some of these links actually say that you can't use the lowest settings on some bikes, and now I see why.
ORIGINAL: Jeff1980
....On the lower setting the shock itself hits the mounting bracket even before the hole for the lower setting is lined up with the bracket.
