Jetting?
Old May 27, 2007 | 07:20 PM
Juanage69's Avatar
Default Jetting?
Hi, I just bought a slip on and a k&n air filter, do i need to rejet my bike before installing these? thanks
Old May 27, 2007 | 08:57 PM
FNQuickF2's Avatar
Default RE: Jetting?
Usually you do need to rejet carbs with new exhaust...There are a few makers that don't require rejetting...Aftermarket mufflers have better flow...along with a less restrictive air filter, you are now moving MUCH more air, in turn, you need MUCH more fuel, otherwise you will be running a lean mixture which generates alot more heat...NOT GOOD! You may start melting pistons if ran under theese conditions...
Old May 27, 2007 | 10:01 PM
edwardtn's Avatar
+1 with FNQuick...with just a slip-on you may run fine, but with a slip-on and a K&N...probably would need rejetting...at least to get the most out of the increased airflow.
terryzrx1200
Apr 20, 2009 11:20 PM
Trunks
May 1, 2008 08:31 PM
tank_900rr
Nov 11, 2007 04:59 PM
zinccut
Oct 10, 2007 06:44 PM
DempsRS
Jul 12, 2006 02:05 AM
