i need some help
the problem is when it idles after riding for a long time it turns off on me. it happens when i disengaged the clutch. if i keep my bike in gear when slowing down or i give it gas she stays running so for now i pop start my bike if it turns off when im riding hopefully it dosent damage anything.
sorry about my last post.
sounds like it might be overheating or something. when i had my f2 it was really bad at heating up on me and i heard that that is a common problem with them so i would keep an i on that when riding
Well the temp was low but after I turn her on again and she was fine I read about the idle jets they get dirty and it sed that they worke till 5000rpm then it uses the normAL ones after that I just wanted to know if anyone out there had this problem I really don't want to take my bike apart for an easy fix you know I know that I have no water on my radiator side tank.
You should add some coolant to your radiator overflow tank (on the side) if it is empty. why wouldn't you? it is easy, take off lid, poor in coolant, close the lid.
You are probably guessing correctly, the idle jet(s) could be partially restricted causing your bike to die at idle. since the problem doesn't seem to be too bad and you don't want to dig into the carbs for a fix you could try just turning the idle up so it is less likely to die.
A helicoil kit would probably suffice. I don't think those holes go all the way into the case so you should be able to avoid getting metal shavings into the engine...
