I nedd info
Thank you wrango, I felt like this was going no where. blacken, u have your solution with the spacers, you could also go with a heavier weight oil, f3 front end gsxr front end, lose weight, cut off a leg, yoga, ride from the passengers seat, and another number of things. Hope this helps.
if the front end sags an inch from full extension with rider, thats about right. look in the manual to see what your preload sag is supposed to be. i think its around 30mm, which is just over an inch. any more than that, you will need to put in spacers to set the preload or replace the springs with stiffer ones for your weight. checking/changing/upgrading you fork oil is a good thing to do anyway.
JesseAwesome
F2 Tech
08-01-2010 09:40 PM
