How much oil is too much?
I always try to get my oil level as close to full as possible without going over, by "eyeing" it. I guess I don't have time to bother measuring. I always seem to put just a little too much in. Today, after an oil change (3 quarts regular, 1 quart synthetic, 5w 30), I topped it off just about 3-5 milimeters above the TOP of the "full" line. It was a long day and I was just too tired to drain anything and left it. At what point does one need to worry about engine damage from overfilling the oil? Or better put, at what point should one drain excess oil. Thanks!!
Thats a pretty good question. I'm pretty demanding on myself when it comes to changing my oil and checking the level. It may not sound like alot but the case on these engines is smaller then a vehicle. Being over what appears a small amount, may actually be too much in these smaller engines. That being said, I've put almost 4 quarts in mine, but never 4 exactly. If its 3-5mm over, is this before you turned it over to get the oil through or after? If its after I would probably drain a bit. But then again I could just be paranoid. I just prefer to err on the side of caution.
Thanks, yeah I just left it. It's really not too much overfilled I don't think. It's almost like the oil climbs up the stick and flattens out a bit if you don't take it out and read it really fast. Either way, I don't think my engine will complain
