Hose Location.
Old Jul 3, 2009 | 01:01 PM
CWBerube's Avatar
Default Hose Location.
Hello Everyone.
New to the forum and Hondas and need a little help.
I have just purchased a '93 F2 and I did a carb cleaning on it as it was running just horrible.
I put everything back together and it runs much better.
But I did have 1 large about 1/2 to 3/4 inch hose coming from the bottom of the airbox.
It's hard to get a good photo but it's at the top of this post.
I'm also including a few shots of how dirty the carbs were.
Can someone let me know where this large hose goes to or if it just gets capped off.
Thank you very much!
Chris
Old Jul 3, 2009 | 02:27 PM
frozenpoet's Avatar
I'd like to say that that is a vent tube and isn't attached to anything. Not 100% though from that pic.
Old Jul 3, 2009 | 02:30 PM
fsjeeper's Avatar
id say thats a drainage hose for any moisture that may be in your airbox
Old Jul 3, 2009 | 03:31 PM
Dissevered's Avatar
It attaches from the middle of your carbs and goes into that little filter box on the bottom of the air box. point the hose the other way, you should see where it goes. heres a pic.
Old Jul 3, 2009 | 03:33 PM
Dissevered's Avatar
actually, upper right of your 2nd picture and lower right of your 4th picture is the dark tube you attach the hose to.
Old Jul 3, 2009 | 04:02 PM
CWBerube's Avatar
Post #4 is exactly what I was trying to get a shot of.
And I see now it's backwards and I'm going to have to take the gas tank off to get to it I believe. (It's a pretty tight spot and I just filled the tank up. Blaaahh!)
Sorry for the horrible photo.
Had to use an old Samsung 1.0 megapixel with no flash.
My Panasonic piece of junk digital camera decides when it wants to function.
Constantly says replace batteries even though they're brand new.
What is the purpose of this hose if you don't mind me asking?
The bike runs much much better even without it hooked up but I don't want to ride it much without it attached.
Can't see it on the service manual for some reason.
Thank You!
Old Jul 3, 2009 | 07:17 PM
Dissevered's Avatar
It is a breather hose of some sort. not sure exactly how they work.
Old Jul 6, 2009 | 04:30 PM
g32bturbo's Avatar
those are relatively clean carb bowls compared to what mine looked like, hahah. also, with that much rust in the carbs you might want to check your gas tank to make sure it's not rusted in side.
PILGRIMSUPPORTER
Dec 16, 2011 08:45 AM
suthernoutlaw
Apr 27, 2010 08:30 PM
dpnut2
TRG Coating
Dec 4, 2007 02:36 PM
bieniu
Sep 21, 2007 10:50 AM
AlpineCBR600
Dec 17, 2006 06:29 PM
