Headlight out....
Last night when I got off work, I went out and started my bike.... While doing so, I noted that it was rather dark in front of the bike... The headlight was out... Since it was dark, and I had no tools of any kind (not making that mistake again), I couldn't do anything about it at the time.... Today, I get up and check the fuses, they're fine... Took out the headlight, and it looked fine, but I went and bought a new one and tried it, but it didn't work either... I noted that the top (middle) prong socket on the plug had a dark spot, as if there was a short, in it...
It had been rained on while I was going into work, and then while I was at work for a bit... Anyone know if I can just replace the wire if I find it to be shorted, or if I need to replace an entire harness??? Any input would be greatly appreciated. Dave |
RE: Headlight out....
ok bro the headlight swich on the left handle bar see if thats gettin power, If not it runs into the right handle bar on off swich see if the soter joint brok off thats usually what happens if not pm let me know
Eph1zzle, thanks for the info... Finally got a chance to check things.... Yes, it was a bad solder.... Re-attached it, and all is good now... Man, this forum rocks.
Dave |
