Good news but one small bad...
Hey guys, as you all know I had a really bad time with my fork rebuild. So I got a new used set which was in a way better condition than my old ones with new seals about 5k miles ago. So now I have the bike up and I'm still having a clutch problem. My clutch was fine before the tear down. I didn't touch anything and I put everything back recently.
Here's a given situation as to which I can't understand.
I start my bike, its in neutral, runs fine purrs like the lion she is. Lol. Anyways, so I let her warm up for about 2 mins, then right as she clunks into first gear with the clutch lever pulled all the way in, she just dies... I adjusted the cable so it would catch higher / make it easier to have the clutch disengaged, but it helps nothing.
Just for verification, say the motor is off. When I put her into first gear, is there suppose to be a slight drag / tension when I roll her forward or backward? Or is it suppose to be as I'm gliding on ice? Because as of right now, she rolls forward but with a slight resistance on her. I can't remember if she was like this before because its been 5 months.
So if anyone has any suggestions, let me know.
I will record a video and post it to show you first hand soon. (If anyone knows how to edit videos please edit mine as I have no idea.)
-Jasper
-Jasper
if the bike is off and you have it in first with the clutch let out, it should not roll. you will feel the resistance at the wheel. as for it dieing when you put it into first when the bike is running, im not sure what to say about that. maybe someone else will chime in
With the clutch let out, it doesn't roll. But when I pull in the lever it rolls free, but has a slight resistance. Its easier pushing in neutral than it is in first (or any other gear) with the clutch pulled in when it should be the same correct?
-Jasper
-Jasper
i see what youre saying now. i dont think there should be a problem pushing it with the clutch pulled in. i notice a difference compared to neutral but its more of noise than any kind of resistance. pushing the clutch in is supposed to be the same as neutral as it dissengages the engines from the wheels, however, just like in a car, im not going to be rolling around with the clutch pulled in for any amount of time. if i want to coast i'll shift to neutral, its just feels betteri think.
but back to your question,i dont think there should be any significant amount of resistance, it should still roll free
The side stand switch is what I'm exactly thinking but I never knew which switch. The previous owner removed the switch. He removed everything of it except the side stand =P. What should I do with it to make it work?
-Jasper
-Jasper
Well I figured it out. I was wondering what the did with the wiring. Apparently he removed the sidestand switch and cut about two finger lengths of slack on the male connector for the switch. They just spliced and connected the two green wires to run without the side stand. I on the other removed it because I thought it had no purpose... I was wrong. lol. It did. Thanks guys for the help.
-Jasper
Anyone got any lower left cowls pieces hanging around? It doesn't matter if its broken. I'm trying to fix my upper cowl. Today, I made custom brackets for the headlight as there wasn't any for the headlight to mount to when I got the bike. They just made custom brackets so the headlight would be held by the fairings stay. Looked pretty cheap to me. So I had to make something better.
-Jasper
