fuel pump question
Old Nov 24, 2006 | 02:51 AM
mk3turbo's Avatar
Default fuel pump question
the bike i just bought didnt come with a fuel pump, i was wondering if a 98 f3 fuel pump would fit on my f2?
Old Nov 24, 2006 | 09:44 AM
mikeyvis's Avatar
Default RE: fuel pump question
does the 92 have a stock fuel pump.the reason iask is that i cant get fuel to carbs and now you have me thinking .any ideas
Old Nov 24, 2006 | 12:38 PM
mk3turbo's Avatar
well after doing some more research, it comes to my attention that they didnt come with a fuel pump, but the dealership said they did. who has the right answer and if they dont have a fuel pump then how the hell does the fuel get regulated into the fuel rail?
Old Nov 25, 2006 | 10:34 AM
mikeyvis's Avatar
you have a air line from the manifold to the petcock that controls your fuel if i am right.i am trying to figure this all out know being a new owner of a94 f2 that wont start. being i have a fuel problem i think.
Old Nov 26, 2006 | 01:58 AM
LaynLo17's Avatar
f2s didnt have them, the fuel pumps started with the f3s.
Old Nov 26, 2006 | 10:29 PM
mk3turbo's Avatar
anyone have the fuel hose routing for the f2 so i can get my bike started? any information or members pics would be great.
Old Nov 27, 2006 | 12:38 PM
Way Fast CBR's Avatar
f2's dont have a fuel pump, they are gravity feed by a petcock on the gas tank. but for it to work there is a vacum line that comes from the number 1 cylinder just under the carburator. its on the left side of the engine as if you had the bike pointing forward. a rubber hose goes from that to the petcock. and when there is vacum a rubber vavle opens and lets the fuel flow. when i get home from work i can take a pic of the petcock and vacum point for reference, thought my bike is taken apart it should still point you in the right direction
Old Nov 27, 2006 | 01:44 PM
mk3turbo's Avatar
that would be great if you could do that with the pictures. Thanks in advance!
Old Nov 27, 2006 | 01:45 PM
mk3turbo's Avatar
i also need to know where the three outlets on the top of the carbs go. There are two small black outlets on each side then i a bigger outlet in the middle, i think the two on the left are a fuel hose but im not sure...if you could take a picture of that as well thanks again man
Old Dec 27, 2006 | 10:12 PM
WHY_NOT???'s Avatar
sorry guys old post, but i seem to be having the same problem as the above member and i am absolutely going nuts.
the bike runs great if u push it down the road a few times and drop the clutch and finally it trys to start forcing fuel into it, but just trying to start it off the button when its cold it wont do ****.
i am missing quite a few parts and if anyone could be more specific about the whole vacuum fed fuel thing that would be of great help
