Front end question...
Old Sep 2, 2006 | 12:26 AM
LouSiffer's Avatar
Default Front end question...
I have a 91 CBR 600 F2 and noticed that in slow traffic when coming to a stop light, I usually hit my front brak harder to make the weight of the bike dip forward to make sure the lights weight sensor is set off so as not to sit at the light for 20 mins getting skiped when I'm first in line or alone. When I do this I noptice an ever so slight feeling that someting is loose or hitting.. Bike front dips and you feel a slight <bonk>/<click> feeling. I have went through and wiggled every piece I can by hand and found nothing to be loose and also checked for clearances when the suspension compresses. Any Ideas what this could be?
Thanks in advance.
Old Sep 2, 2006 | 05:11 AM
ep03TN's Avatar
Default RE: Front end question...
Not sure about the mechanical part of your question, but here in TN it is legal for a motorcycle to stop at any redlight and run through the red light as long as traffic is clear (because the bike doesnt weigh enough for the sensor to trip the light.) Might check the laws where you live.
Old Sep 2, 2006 | 07:02 AM
mikequinn's Avatar
Could just be the head stock bearings, you can't really feel the wear unless you move the fork legs, unless they are totally shot.
you could also try a heavier oil in the forks too, to stop it diving...
Old Sep 2, 2006 | 07:03 AM
LouSiffer's Avatar
Will do. I hate when I get skipped at the light, I always there looking around alone thinking...Should I? Then the thought of some cop camped out watching me in a hidden location pops in my head and I reconsider. LOL
Old Sep 2, 2006 | 01:44 PM
racer212's Avatar
I'm with mikequinn... sounds like steering head bearings to me. I've heard wheel bearings make that noise too, but if they are that bad you'd notice it in your handling too.
Old Sep 2, 2006 | 08:48 PM
02_GSXR_HYBRID's Avatar
these bikes are commonly in the shop for steering head bearings. that sounds like your problem. if not that it seems like you have some fork internals not functioning propely.
and FYI, red lights dont have weight sensors. bikes dont have enough metal on them to change the red light. there is usually a smaller box on the front left corner of the inductance loop in the road. that box is for motorcycles to place their front wheel in to get the light to change.
check out this article to learn more about them
http://auto.howstuffworks.com/question234.htm
Old Sep 2, 2006 | 09:03 PM
LouSiffer's Avatar
Any Idea what the approx cost for replacing the steering head bearings on the bike runs? Like to have a shop do it and/or to do it yourself if its not too involved..
Old Sep 3, 2006 | 02:01 AM
the bearings themselves are real cheap. its taking the front wheel, forks, triple trees, and steering stem out that is labor intensive. you should be looking at about $200 to have a shop do it, maybe a little under that.
Old Sep 3, 2006 | 07:08 PM
jasonty's Avatar
Agreed. It's the steering head bearings. If you go over a bump, and you feel something loose in the front end, that's the steering head bearings. Also, try shaking the front tire side to side with your hand and check for play. This will indicate bad wheel bearings.
diovol
Feb 3, 2011 11:56 PM
trajiks9
Sep 16, 2008 07:21 AM
HAVOC
Feb 9, 2008 12:27 AM
F4Stunter
Dec 2, 2007 12:43 PM
monty1krr
May 21, 2007 10:51 PM
