front brakes cbr600f2 1992
Sounds like you're running the wrong brake fluid. It says run DOT4 for a reason!
If you didn't make that mistake, it's likely that your brake lever assembly is either improperly configured or needs service. New seals, o-rings, springs etc kind of deal.
Does the feel in the lever change at all?
Does the level in your fluid resevoir change at all?
