Front 3 piece fairing question
Old Sep 28, 2009 | 11:46 AM
Smittypig24's Avatar
Default Front 3 piece fairing question
Can I merge my front 3 piece fairings together into one? If I do, is it really hard to mount it or will it go on with no problems? I've had to repair some of the side uppers and if I weld them to the middle fairing, it will make them stronger. I think I've seen other people with all 3 seamlessly welded together.
Old Sep 28, 2009 | 11:54 AM
Krux's Avatar
Hmm not sure if you would want to. I think it would make it harder if you ever need to get anything off.
Old Sep 28, 2009 | 12:47 PM
Bently600's Avatar
The other people with 3 in 1 seamlessly probably have one piece fiberglass ebay uppers (they aren't very good).
Old Sep 28, 2009 | 04:14 PM
frozenpoet's Avatar
I have a fiberglass one and it's not very good, doesn't line up right. I only live an hour away from you and I'll have my bike out the next two days. if you wanna check it out closer I can take a ride that way.
Old Sep 28, 2009 | 08:22 PM
JimmyHoffa's Avatar
+1 for eFairings sucking. Mine came with one and I'm on a mad search for stock upper fairings. I'd rather ride it naked than with an e-fairing. I was convinced my fiberglass one-piecer wasn't even for my bike until I found a part number and proved that it was, in fact, just a really really crappy fiberglass fairing intended to somehow fit on my bike.
Old Sep 28, 2009 | 10:42 PM
Ahh...thanks for the input. I guess I'll just weld/fiberglass the hell out of the puzzle I put together then. Finding these uppers at a reasonable price is proving to be next to impossible!
On a similar topic, can I buy the OEM sticker set that is on my bike? I've seen colorrite sells the OEM paint I'll need.
Old Sep 29, 2009 | 09:33 AM
JimmyHoffa's Avatar
I feel ya man. I'm on a mad search for stock upper fairings, rashed or not. The pickinz' are slim.
You can cross your fingers if you want , but I've had some atrociously expensive bad experiences with colorrite. I bought their whole system to re-paint the lower a-arms of my YFZ450 quad, and it wasn't even close. I went to the local paint shop with the part that was the color I needed, and the guru there made a ridiculously good looking match. It was about half the price, and had the metal flake as part of the base coat as well, so I just needed to primer, base and clear as usual. Of course, if they didn't get it right some/most of the time they wouldn't be a business, but I'm done with that junk.
Old Sep 30, 2009 | 01:59 PM
frozenpoet's Avatar
took a couple pics of my alignment issues with my targa upper
Old Oct 12, 2009 | 12:17 AM
destindiver1980's Avatar
I do agree with the efairings sucking. However I have seen a new post started a couple days ago with a top fairing only for 135. Comes in 3 pieces, not seamed together. They look alright would be interested in how they fit. Link below...
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Oct 12, 2009 | 05:51 AM
ZIP5K's Avatar
Talking maier
Maier makes one out of A.B.S. plastic. But its a race upper with no headlight cut out.I modified IT to use stock headlight. I cut the inside trim from the old one and used plastic weld to hold it. I tied down the headlight from the inside to keep it in place. for $123.95 it was worth it for me.
