F3 to F2 front
RE: F3 to F2 front
Why not look into a basket case F2and make one out of two. Sounds like an exspensive job for a tach and speedodometer. I usually ride by sound anyway. Normal riding if it sounds sorta high I shift. Having fun if it sounds kinda high I NAIL IT!!!!!!!!!!!! only a little bit
RE: F3 to F2 front
ORIGINAL: killerc998
lol. from what iv been understanding on the swaping is i gota do forks, axle, rim, brakes, rotor, speedo cable, cluster, then wire cluster to work properly for tach and other eletrical gauges. i kinda need the speedo im just learnin to ride so i cant tell by rpms
RE: F3 to F2 front
thanks for yalls help some one on the f3 side sugested this. http://www.sportvue.com/store/product.php?pid=14 its prolly cheaper to do it this way.
RE: F3 to F2 front
or you could get a http://trailtech.net/vapor.html, VAPOR by trailtech. $120ish out the door. check here http://www.rockymountainatv.com/
