F3 cams
Old Dec 29, 2008 | 08:30 PM
mrbf2's Avatar
Default F3 cams
will F3 cams and jets work in a F2 i have my cams but my carbs have no jets or needles
Old Dec 30, 2008 | 07:41 AM
Rickracer's Avatar
Default RE: F3 cams
I don't know about the F3 cams (be interested to know the answer to that one too, and if there's any difference in performance), but I'd invest in a jet kit for the carbs. [8D]
Old Dec 30, 2008 | 12:51 PM
mrbf2's Avatar
Default RE: F3 cams
everything read says they'll fit but with no direct answer and all the cam makers classifiy them together but I cannot find F3 specs so I think I'm gonna try running two intake cams now all I will need is jets
Old Dec 30, 2008 | 03:29 PM
powerban's Avatar
Default RE: F3 cams
I dont think you can run 2 intake cams like you can on a V-twin. You're also gonna have to do a valve adjustment either way.
Old Dec 31, 2008 | 03:18 PM
cowboy from hell's Avatar
Default RE: F3 cams
dont know about cams but the jets will work the youll love the pilot but the main is way too big for a f2 because the f3 has ram air.
Old Jan 3, 2009 | 05:57 PM
mrbf2's Avatar
Default RE: F3 cams
I dont know how 2 intake cams will run but im postive it will work as it will in any dohc engine (almost) its just a cheap way of getting more lift, as for the jets they are free just like the bike i just have to assemeble it and if it makes it one block ill be satisified I'm trying to make a daily driver the bike was in a million pieces and the frame is pretty bad shape one block and its sold for parts
Old Jan 4, 2009 | 11:58 AM
Sand.Man's Avatar
Default RE: F3 cams
The jetting is different on F3 carbs, they actually use 2 different main jets in the carbs... 138 in 2 of the carbs and 140 in the other 2.
I'm sure they would fit but it would be a headache trying to get it to run the way it should.
Old Jan 6, 2009 | 02:50 AM
vallip's Avatar
Default RE: F3 cams
Hi there,
I installed F3 carbs on my F2 last winter, including the ram air system. I also installed a dinojett kit stage 1 and the motor ran perfectly.
I was sure it would be a nightmare to get the jetting right but this time it was the easiest re-jetting job I have done.
picks of the mod www.flickr.com/vallip
Old Jan 6, 2009 | 05:49 PM
Quickslick444's Avatar
Default RE: F3 cams
ORIGINAL: vallip
ugh your bike is so clean... how many miles... 5k?
Old Jan 6, 2009 | 06:04 PM
Default RE: F3 cams
ORIGINAL: vallip
Hi there,
how much power did it give you?
