F2 Wheelies
Old 06-28-2005, 02:31 AM
Phazin's Avatar
Default F2 Wheelies
Anyone able to pull their F2 up? i havnt really tried only because i dont wanna pull 2 hard... My old 929RR i just nailed the throttle and Whamo instant Wheelie... this one just GOES lol..
Old 06-28-2005, 02:35 AM
Phazin's Avatar
Default RE: F2 Wheelies
and if so... any tips... RPM, GEAR? How hard to pull?
Old 06-28-2005, 03:00 AM
my first bike was an 93 f2 . i had to rev the throttle to about 6k and dump the clutch for it to come up in first gear. and in second gear was almost to 9k if i remember right. hope that helps.
o yea i also droped 1 toothion the front sprocket and added 2 to the rear, that seem to help but i still had to pop the clutch in either gear.
Old 06-28-2005, 04:02 PM
ive got an (93)f2, it takes a little bit of feelin it out, but mine will pop up if i gun it off a start. If im rollin in first i gotta clutch it up. In second i definitely have to pop the clutch hard. I dont screw with it too much, but itll come up. I dont get 12oclock wheelies , I get more like 2:30's...
Old 06-28-2005, 05:50 PM
Ive tried a few times to get mine to wheelie in second without using the clutch but i have been unsuceessful, so i tried doing it in first around 4000 rpm in let off the throttle to compress the front suspension and then gunned it and the front wheel came up pretty fast, it actually scared me enough for me to let off the throttle pretty quickly. To my knowledge the bike has stock sprockets. hopefully this is what you were looking for
Old 06-28-2005, 07:28 PM
Hey good info. I'll have to try that sometime, but not for a while. I just got my F2 about a week ago so I am still just breaking the surface. The power is still intimidating me, and I'm not quite used of how fast it slows down when you let off the throttle. I am getting a lot more comfortable with it, but I still keep it below 6k 90% of the time. I've only brought it above 6 a few times, and once to 11, and it was quite a rush.
Old 06-29-2005, 01:19 AM
Hey I'm new at this forum,but I had some trouble at getting my 94 f2 up,so I got a street stunt sprocket from thrust company,and it went up 9 teeth on the rear and down one on the front,this made a humongous difference,it cut the top end a little bit but it comes up real nice the have different levels of sprocket kits,some add 2-4 in the rear and on the extreme side some add 20 in the rear.
Old 06-29-2005, 03:04 PM
Phazin's Avatar
mine is also geared down in the front nd up and the rear i feel it wanting to in 1st but i dont want it to come back on me, im a heavy guy 240lbs so me tuggin on the bars will make this thing come up lol i just need to feel it out i guess.
Old 07-04-2005, 12:56 AM
Its simple to wheelie the bike.
This is a detailed instruction runthrew of how i do it.
Bring the bike to 10grand in rpms.
Let it drop to 8grand letting off the throttle.
then just pin the throttle and kinda bullback and the front should slide its way up.
now when your up throttle controll is key. DONT KEEP IT PINNED AND DONT LET GO ALL THE WAY.
once you find the balance point and want to stop let the throttle go and then pinn it wide open and you should come to the ground smoothly. ****f instantly to 2nd cuz you will be close to redline
thats how i do it
Old 07-08-2005, 02:19 AM
Hey man you'll have to use the clutch with the f2. It doesn't have the wheelie power of a 929RR LOL. At least your F2 starts. Mine will not, I'm very depressed!!!! lol
Quick Reply: F2 Wheelies
