f2 wheelie sprockets?
ORIGINAL: Ryuu600
first off. Any larger sprocket you install is going to lower your top speed. PERIOD.
The larger the rear sprocket or smaller the front sprocket the more rotations it requires of the engine to rotate the wheel, which means a lower speed will be accomplished at the same rpm.
Second. pulling wheelies at 60 on an F2 is gonna require probably -2 up front and like +4 or more in the rear.
go for -2 front & +4 rear
First off - what you really need to do is find out where peak torque is. Then pick the speed you want to wheelie at. Then pick a set of sprockets that puts the peak torque at about that speed...
I used metric but you can convert after.
Find the circumference of the rear wheel:
17" wheel * 0.0254 + (tire width * tire profile/100 / 1000) * pi = circumference in metres
speed = ((PEAK Torque RPM) * 60minutes) / (Primary reduction * 2nd Gear Ratio * Final Ratio (ie. 45/15 for F4)) / 1000
Put in the speed and solve for final ratio...
I'm going to make a webpage up to do this... keep it simple.
New Top Speed = (OLD TOP Speed * New Final Ratio) / Old Final ratio
Going -1,+2 on the F4 is a 14% change... so my top speed dropped from ~268 to ~244 (from memory)
If you get the primary reduction ratio, the gear ratios and the stock sprocket size... and the tire size I'll put it in my speadsheet and make it available...
I made the spreadsheet for picking gears for my F4... it has the F4's torque and hp curves matched to rpm... I've been using it to pick the next sprocket set I buy. I'm kind of partial to -1,+2 as it doesn't change top speed much, cruising rpm isn't too much higher but I get a definate punch in the lower speed turns. Stock was 16-45 and I'm now 15-47 fwiw.
I've got a 93 f2. Went -1/+2 and a 520 chain. Front wheel comes up like mad in first and second. Top speed dropped about 15 mph (from about 150-155 down to 135mph) Cruising @ 80mph bike runs 7500rpm. Not really sure if I like running that kind of rpm's on a consistant basis but it is a blast through town and on shorter trips. Just finished a 350 mile ride and the fuel economy dropped (hit reserve @ 140 miles). Think about what kind of riding your going to do and how long you want keep that cbr alive. Are Wheelies that important? -2/+4 and I'd keep it in town and parking lot side shows.
