f2 rear turn signal delete need help!
ok so i want to reomove the stock rear turn signals and move the license plate up and tuck it all up tight and neat.... i want to do it my self and i cant seem to find any how tos on it..can some one help
I have looked for diy's for that too, no luck. Just go out there and dedicate a half day and knock it out. Take your time, take pictures to make sure you have everything where it goes, and make a how to when you're done. I dont think it'll be that difficult of a job.
alright i will thanks ... i am also trying to wonder where to mount my hid ballast? right now i have it under the odometer but i feel as if its hindering my turning to the left
where did you grab the hid kit?
the way i did it: remove tail light, put it in the oven to seperate the housing from the lens, mount a piece of black plastic directly down the center so that it will fit from the housing to the lens, and the light will not pass through the plastic so only 1 side will blink, put the 2 pieces back together, drill a hole in each side of the housing for a 194 socket then just wire everything in
