f2 rear turn signal delete need help!
the way i did it: remove tail light, put it in the oven to seperate the housing from the lens, mount a piece of black plastic directly down the center so that it will fit from the housing to the lens, and the light will not pass through the plastic so only 1 side will blink, put the 2 pieces back together, drill a hole in each side of the housing for a 194 socket then just wire everything in
