F2 Question
Old Nov 18, 2008 | 07:23 PM
goldnnght19's Avatar
Default F2 Question
will a 900rr rear rim fit in a f2 swing arm just wondering i want a little wider rim and tire or what would work. and wanna stretch it out and anyone know where i cant find 10in or more swing arm
Old Nov 18, 2008 | 07:48 PM
Hurricane rider's Avatar
Default RE: F2 Question
I dont know if a 900 rim will, but the F3 will bolt right up, and fits a 180 tire.
stretching a bike like the F2 is a waste.
Old Nov 18, 2008 | 08:11 PM
thanks. im bored going for something different. is a f3 5.5 rim
Old Nov 18, 2008 | 08:41 PM
Sand.Man's Avatar
Bored? buy a new bike :P
Old Nov 18, 2008 | 09:00 PM
I'm pretty sure the F3 rim is a 5.5" rim. if you're bored, why not try taking on an F4i or RR motor swap? that'll make it a way more fun bike.
Old Nov 19, 2008 | 07:39 AM
im gonna look into that f3 rim. and look into a swap the reason have notdone anything like that is cause i dont have deep pockets jus little things to change it alittle i dont know looking for ideas really i like the 900 swap the f9 thats real sleeper
Old Nov 19, 2008 | 10:08 AM
99LS1's Avatar
Sorry op for jacking this thread hope you dont mind....
Im going to add to the question a little bit, Is there anything you have to mod? Can I take my rotors off the f2 and put them on the f3 rim? I thought it was going to be to wide for the swing arm???
Thanks!
Old Nov 19, 2008 | 11:40 AM
yes, you should pretty much be able to remove your running gear from the F2 rim and install it on an F3 rim,then just bolt and go, then smile at wider rear tire.
Old Nov 19, 2008 | 12:06 PM
99LS1's Avatar
ORIGINAL: Hurricane rider
You sir, just made my day......
How much do they usually run (F3 rim)?
Thanks again!!!
Old Nov 20, 2008 | 05:14 PM
99LS1's Avatar
How about axel, spacers and rear rotor???
