eletrical problem
Old Sep 4, 2006 | 05:35 PM
wetwillymd's Avatar
Default eletrical problem
ok fully charged a new battery and put in a new regulator/rectifier. and started up the bike took it for a ride and then it just lost power and killed. every time a charge the battery the bike sucks it down in less than a day. any advice would be greatly apreaciated thanks.
Old Sep 4, 2006 | 05:43 PM
mikequinn's Avatar
Default RE: eletrical problem
Have you checked the charging rate with the bike running??
Old Sep 30, 2006 | 09:19 PM
wala's Avatar
Was wondering if you found the problem.............I'm kinda having the same problem a couple months ago my main fuse blew and every time i put another in it would blow so i installed a new wire harness and it was fine for a month then the bike died on me (no power) so i bought a new stator since i already put a new rectifier on it and battery and it stilll wont charge any info would be appreciated....thanx kurt
Old Sep 30, 2006 | 09:50 PM
mikequinn's Avatar
The charge from the rectifier comes back into the starter solenoid through the multi plug with the main fuse in, Check to see if there is any corrosion on the terminals or in the multi plug. looks like green crud, also 2 big cables run across the relay remove the allen screws CAREFULLY!!! if they are corroded and clean those too one goes to the + on the Battery the other goes to the Starter, Oh yeah just a pointer Disconnect the battery 1st....
YOUGOTHEBREAk
May 13, 2012 09:37 PM
oprprspcrmgr
Jul 11, 2011 03:34 AM
icreepin
Jun 20, 2008 10:17 AM
hondadriver4life
May 11, 2008 10:58 PM
