Drive sprocket removal
Old Jan 28, 2008 | 02:01 PM
SJN's Avatar
SJN
Default Drive sprocket removal
Hi Guys.
Im having trouble removing the small drive chain sprocket on the transmision......damn thing is on very tight.
How do you get it off ?
Is it a leftthread or normal?
I put it in first gear to stop it spinning, but i still turn the engine......
Hope you can help, thanks
Old Jan 28, 2008 | 03:26 PM
SpecR's Avatar
Default RE: Drive sprocket removal
Impact wrench.
Old Jan 28, 2008 | 03:32 PM
SJN's Avatar
SJN
mmm... i thought you would say that....but I have disassembled the wholebike in a celler without any electrical power available....
Old Jan 28, 2008 | 04:34 PM
reydelaplaya's Avatar
Try putting it into a higher gear, should be harder to turn the engine in 6 than 1. Otherwise, put the chain on along with the back wheel, and use the rear brake to provide the counter resistance. Looks like it should be a normal threaded bolt.
Old Jan 28, 2008 | 06:25 PM
SJN's Avatar
SJN
Thanks, ill try put it in 6th.
Old Jan 28, 2008 | 07:46 PM
FNQuickF2's Avatar
ORIGINAL: SpecR
Impact wrench.
YEP!
Old Jan 28, 2008 | 09:53 PM
elmer's Avatar
I did it by putting it in a higher gear. That'd be the easiest way without an impact. good luck!
Old Jan 28, 2008 | 10:24 PM
SpecR's Avatar
Battery powered impact wrench (on sale at harbor freight for $40).
I just bought one...
Old Jan 29, 2008 | 11:05 AM
SJN's Avatar
SJN
Thanks guys.
I managed to get it of gently tapping my socket wrench with a hammer, and the bastard fianly came off
[IMG]local://upfiles/19410/1E3BA7C2379D4C22912B63E9ABE0AB44.jpg[/IMG]
[IMG]local://upfiles/19410/9831BA425FE0457386645EA3418ADD80.jpg[/IMG]
Old Jan 29, 2008 | 11:07 AM
SJN's Avatar
SJN
more pics
[IMG]local://upfiles/19410/9FD9D30C3CF44D26988DB620F8C6CB45.jpg[/IMG]
[IMG]local://upfiles/19410/9ED25704E8084CBA929ECAC0B6EEF972.jpg[/IMG]
