Drive chain specs??
Old Jul 17, 2010 | 12:45 PM
jalate compa's Avatar
Default Drive chain specs??
Does any one knows the stock drive chain specs?
i mean how many links size ?
Old Jul 17, 2010 | 05:58 PM
underground-mpyre's Avatar
Before everyone makes fun of you. Go to Motorcyclesuperstore.com. Most people use DID chains X's or O's. Either we have a 520 or 525 or 530 chain. Honda spec is 525, race is 520 or city retards like me use 530 which use more Hp than what is worth. 530 more control IMAO in corners.
Old Jul 17, 2010 | 08:48 PM
Y have a regina 530 but i dont know how many
links dose it have
Old Jul 18, 2010 | 11:27 AM
adrenalnjunky's Avatar
# of links would depend on the gearing. Stock is a 108, some gearing combos might drop to a 106.
Old Jul 18, 2010 | 07:57 PM
JesseAwesome's Avatar
You add links for most gearing change, unless they are significant drops on the front tooth.
Old Sep 24, 2010 | 06:30 PM
Davidrun33's Avatar
stock f2 chain is 525 / 108? I coulda swore I read 530 / 108.
Old Sep 24, 2010 | 06:36 PM
Yes... 525, 108 links is stock on the F2.
If you want to make the most of this bike on the street, I advise you go with a 530 chain, and go up three teeth in the rear. Get a chain that's too long (110+) and simply remove unnescessary links then rivet it on.
The sprocket change will incresae acceleration, far more than the additional weight of going 530 will adversely affect. 530 chains last longer, and are less prone to failure and tight spots.
Old Sep 25, 2010 | 08:21 AM
Davidrun33's Avatar
sorry to ask a dumb question Jesse but what is the stock sprocket teeth count? Clymers does not list this info for some reason
Old Sep 25, 2010 | 11:00 AM
15/43 is stock.
Old Sep 26, 2010 | 01:03 PM
Davidrun33's Avatar
thanks,
so then a 15/46 with a 530/110 chain would be a good combo?
