digital guages for my F2
Old Oct 10, 2011 | 05:47 AM
CBR_600_freakin's Avatar
Default digital guages for my F2
Hi I bought a 93 F2 and it has now fairings or plastics except for the rear tail area along the seat and tail light. But anyways I plan to make bike back ro stock since it was used as a stunt bike and I heard about guys getting guages off the newer cbr's and I dont have the harness or anything and I would like to go with digital and what all would I need and how much $$ are we expecting here? I plan on eBay 1st option .. your help is appreciated!!
Old Oct 10, 2011 | 07:03 PM
MadHattr059's Avatar
It can probably be done, but does'nt the F2 use a speedo-cable off the front wheel?
If so, it would be a expensive proposition to do a conversion to digital.
Unless you went with one of the after-market units, which commonly run in the $300+ range.
The F3 and beyond get the information from the CDI Unit, so there is some common
ground to make the F3 analog>F4 digital conversion.
I could be wrong, if so, hopefully som-one better informed will correct me. ;-)
Ern
Old Oct 10, 2011 | 07:14 PM
JesseAwesome's Avatar
You can do the F4i conversion, but it requires a CBR 900 case cover as I recall.
Old Oct 10, 2011 | 08:29 PM
TooBroke0029's Avatar
Requires the f4i gauges 900rr front sprocket cover (or vfr) with pick up a speedohealer or similiar. Theres a write up in the tech section check it out, I think some of its actually wrong thlugh, look at the f4i wiring diagram and the f2 to figure it out.
Old Oct 11, 2011 | 03:58 AM
itlnF4I's Avatar
go with trail tech vapor aftermarket cluster. like 150ish i think. i had one on my katana steet fighter and i loved it for the price
derekvercher
Apr 2, 2012 08:21 AM
dustinjklee
Oct 30, 2009 10:42 PM
CBR600F3
Jun 10, 2007 12:45 AM
johnb600f1
Sep 3, 2006 07:38 PM
partyboy
Jul 6, 2006 03:39 AM
