Cowl install
Has anyone installed a seat cowl on their F2 before? I bought one off one of our forum members (thanks again) and now i'm trying to figure out how to install it. There are tabs below it so it doesn't just sit on there, but i don't know if they come off or what. If i can't figure it out i'll just take it to a local shop and have them do it, but i have faith in the community :) Thanks
RE: Cowl install
I'm not 100% sure but I think the tabs mount to the underside of you seat.
RE: Cowl install
PM the member you got it from on install instructions.
RB |
RE: Cowl install
don't break or remove tabs...I have a a maier seat cowl...it slides on from the rear and the tabs go over the bolt on the underside...remove nuts...side it on and reattach nuts...
RE: Cowl install
ORIGINAL: FNQuickF2 PM the member you got it from on install instructions. RB |
RE: Cowl install
Sorry i've been visiting with family in from Pa., but thanks all for the advice. There's a sticker under it that says "We recommend fitting and drilling all the abs body parts before painting" I'm not sure what abs are though.
RE: Cowl install
ABS is a type of plastic. ABS (Acrylonitrile Butadiene Styrene) Plastic
RE: Cowl install
Ah ok that makes sense. Thanks
RE: Cowl install
I can tell you this, If you can't figure it out I would gladly take that off your hands...... I am looking for one.https://cbrforum.com/micons/m16.gif
