CONFUSED
Old Mar 27, 2008 | 10:09 PM
smitty911's Avatar
Default CONFUSED
i know there are many threads on this but i still dont understand. i need to replace my chain pretty soon so ithought about changing the sprockets along with it. i want to know what tooth count to buy and what size chain? i want to get more low end torque so i can launch better and get better wheelies. i do drive on the freeway and stuff like that so i dont want anything too drastic.
do i go down or up in the front?
down or up in the back?
whats a 520?
thanks
Old Mar 27, 2008 | 10:18 PM
black_98civic's Avatar
Default RE: CONFUSED
for acceleration down in front and/or up in rear
for top end up in front and/or down in rear
if i remember most people go -1 in front +2 in back
stock chain size is 530 if you go to 520 the chain is thinner so you loose some weight. you will need sprockets for a 520 chain if you get one
Old Mar 27, 2008 | 10:23 PM
smitty911's Avatar
they come in kits with both sprockets and a chain. do you know the stock tooth count offhand?
Old Mar 27, 2008 | 10:25 PM
15 front and 43 rear
Old Mar 28, 2008 | 06:05 AM
Jeff1980's Avatar
520 chains aren't really intended for street riding. You'll never notice the weight difference with a normal streetbike and the chain will wear a lot faster.Unless you ride like a little old lady, the chain will stretch quite a bit within the first 1000 miles. As far as gearing, go up in the rear. Going woth a smaller front sprocket causes the chain to make a tighter radius which will also reduce chain/sprocket life. 2 up in the rear is about (not exactly but close) to the same as 1 down in front.
Old Mar 28, 2008 | 07:42 AM
city worker's Avatar
Just did mine, droped 1 in front kept the rear stock,14F 43R 530 DID X ring chain
Old Mar 28, 2008 | 07:56 AM
duplago's Avatar
I too went -1 front and it makes a difference. On the freeway I sit at 7000rpm at 75mph if I can remember (its been so long since I have ridden damn Cleveland) www.sprocketcenter.com has some good prices on the kits and they come with the hardended rear sprocket which is really nice.
Old Mar 28, 2008 | 11:51 AM
smitty911's Avatar
whats the difference in chains? what do the different letters stand for?
Old Mar 28, 2008 | 11:54 AM
Sand.Man's Avatar
If anything, go higher in the back rather than lower in the front.
A smaller front sprocket causes the chain to coil tighter around a smaller area and wears the chain faster.
+2 on the rear sprocket is the equivilent to -1 on the front.
For my bike I left the front sprocket stock and went +2 on the rear.
For me, it is plenty torquey and easy enough to wheelie while still retaining highway driveability.
Old Mar 28, 2008 | 12:26 PM
smitty911's Avatar
i think im gonna go down one in the front and up 2 in the back. i found and RK 520 conversion chain and sprocket kit for 150. is that a good deal or no?
