Cold starting F2?
If its cold out, it will crank and sputter to 1000 rpm for a minute then die. I keep crank again and the 1000 rpm sputtering will go longer and longer until it lets me give it gas without dieing, about that time it has warmed up. Somewhere around 5-10 minutes of cranking, sputtering and dieing. Durring the early sputtering if I even think about giving it gas it dies. Are F2's really this cold blooded??
I feel your pain. I tried getting mine started last Monday and Tuesday and killed the battery both times. Having the same exact issue. I'm in the process of checking the ignition wires and coils. Just a note to all else that are responding, if I hit the carbs with starter fluid, it kicks in immediately with no hesitation.
My jets are clean, the carbs are synch'd, the idle screws were set according to specification. When I have full choke on, it might rev once and then die. I think since starter fluid gets it fired up, that perhaps the gas isn't vaporizing or maybe flooding the cylinders. When I do get mine to start, it ends up having the same exact issue as the poster of this thread.
ORIGINAL: Hershey
How cold? I'm usually starting my bike up at 3 degrees celsius, starts fine... are you using the choke?
The springs on the top of the carbs that helps the choke engage tend to fall out,at least mine did.Check your plugs,it's the best way to know what your motor is doing,whether it's healthy or not.
Don't EVER do that.You'll fry your relays and then some.WalMart sells a motorcycle battry charger for 16 bucks.Mine still kicks even after 8 years.
I had to use jumper cables from the car because I killed the battery
ORIGINAL: kjohnson
I figured my problem out.. The choke lever seems to move freeley so I figured I was getting full choke. When it seemed to hit full choke, if I pressed with some force it would move another 3/8" and fire right up. I may just need a new choke cable..
ORIGINAL: Hershey
Or check if there's any room for adjustment, you can possibly clamp your choke cable in the clamp further back to make up for the slack?
