clutch problem!
Old May 8, 2009 | 12:19 AM
CaliKush's Avatar
Default clutch problem!
i tried changin my clutch, put everything back together in reverse order. now i dont even need to hit the clutch to get into gear. and once im in gear i dont need to hold the clutch. but it cant move! i also revved it in first gear and still nothing..anyone know my problem?
Old May 8, 2009 | 12:36 AM
Viking's Avatar
Sounds like yourclutch is not engaging.
Could be something easy: check the cluth cable, that its not too tight.
Otherwise i would say something is wrong withing the clutch assembly itself.
Check the springs and lifting plate, that its creating enough tension on the cluth.
Old May 8, 2009 | 01:00 AM
CaliKush's Avatar
when i tighten the springs down, how tight should i tighten them? all the way down or near finger tight?
Old May 8, 2009 | 07:52 AM
gregtutch's Avatar
the plate and the springs should be tightened right down if you have them finger tight then the clutch is doing nothing and the bolts will only be in about 3 threads thighten them right down and that will solve your problem
Old May 8, 2009 | 12:08 PM
CaliKush's Avatar
sorry i didnt understand anythng u said. when u say tighten right down what do u mean
Old May 8, 2009 | 12:31 PM
CaliKush's Avatar
BY THE WAY! while the bike is on, i can kick it into gear without using clutch at all..and while the bike is off and in gear, i can move it back and fourth as if it was in neutral, but its not!! what do you guys think the problem is/?
Old May 8, 2009 | 12:45 PM
Viking's Avatar
Like gregtuch said, make sure the springs are tightened all the way down.
Old May 8, 2009 | 01:18 PM
gregtutch's Avatar
I cant mind what size socket you need but i think it is 10mm and tighten the pressure plate bolts all the way up in a criss cross pattern. Dont think i can make it any clearer than that really
Old May 8, 2009 | 01:56 PM
CaliKush's Avatar
ooo so tighten the spring allll the way down till i cant tighten them anymore? that doesnt seem right but ill give it a try
Old May 8, 2009 | 08:44 PM
CaliKush's Avatar
fixed! thanks to all to helped =] you were right, i was wrong
