Cheaper gas
Old Jun 19, 2008 | 06:32 AM
eweppley's Avatar
Default Cheaper gas
Well now that gas prices are through the roof, I've been considering putting the middle grade of gas (89 octane) in my F2. I've always run thebest stuff in it. Do any of you other F2 guys run this grade in your machines and if so have you noticed any difference in performance or any other issues using lower grade fuel over premium?
Old Jun 19, 2008 | 06:36 AM
woo545's Avatar
Default RE: Cheaper gas
I actually always run the low grade stuff. Never had a problem, actually. Always very responsive despite that I have a worn boot. The manual even says the low grade is the expected. I'm running stock, so any mods related to the fuel air mixture may apply to you differently.
Old Jun 19, 2008 | 08:10 AM
eweppley's Avatar
Mine is all stock except for the Yosh slip-on exhaust. Anyone else use 87 octane?
Old Jun 19, 2008 | 09:48 AM
redzintimidator's Avatar
a lot of the f3 guys run 87 with no problems...try it for a tank..if you start to hear detonation or pinging you will want to switch back
Old Jun 19, 2008 | 11:06 AM
lonewolfcbr's Avatar
Somewhere on the frame rail of my bike...towards the back...under the plastics...it recommends 91 only....91 is only sold at sunoco's here in pittsburgh(probably the same elsewhere)...i say f it and always put 93 in...15 bucks to fill up isn't a lot....so i can't cry about it
Old Jun 19, 2008 | 11:24 AM
edwardtn's Avatar
Higher octane gas is only less volatile than lower octane (lower octane is actually more "explosive"). The problem comes running lower octane fuels in higher compression engines the fuel may ignite during the compression cycle (as opposed to the ignition cycle).This misfiring results in the pinging. On the flip side a higher octanemay not burn as completely as a lower octane.All that being said the bottom line is thatall of our 14+ year old bikes are different now and you will run most efficiently using the lowest octane possible withoutthe pinging.I always put 89 in and never have had a problem myself.
Old Jun 20, 2008 | 05:53 AM
eweppley's Avatar
Thanks for all of your input. I'll fill up next time with 89 octane and see how it goes. I know the price difference isn't all that much, but it still burns me uppaying over $4.30 a gallon.
Old Jun 20, 2008 | 11:52 AM
kjohnson's Avatar
I've always run 87 and never had any problems.Just use a quality brand (Chevron,BP etc) and not the cheap low rent brands (Coastal, Billy Joe Jim-Bob's gas'n' bait) and you'll be fine.Run a can of Seafoam through it every now and then to keep it in tip-top shape.
Old Jun 22, 2008 | 11:28 PM
elmer's Avatar
I notice my bike runs rougher whenever I use a 10% ethanol blended gas. generally I always run premium, which in Wisconsin here might be 91, not sure. Out of necessity I've had to put 89 octane in which was a 10% ethanol blend and it ran a little bit rough. Not enough to really change the ride-ability of the bike or anything but something I noticed. I suspect it had more to do with the ethanol than the grade of gas though.
jet_vet2003
Oct 24, 2011 10:16 AM
__Z__
Dec 21, 2009 07:43 PM
Speedemon636
Jun 28, 2009 02:02 AM
97si
Aug 7, 2007 01:59 PM
jimmy2blazer
Riding Gear
May 19, 2006 01:20 AM
