Cbr f2
Old Jul 24, 2013 | 01:49 PM
Travis_Hembrook93's Avatar
Default Cbr f2
Hi everyone! I'm new here so I'm gonna get right down to it.. I have a completely modified f2, but lately it has been hard to get it started. I can pop start it no problem, but when I try to crank it over all I do is kill the battery. Any suggestions??
Old Jul 24, 2013 | 01:54 PM
74demon's Avatar
Welcome to the forum.
I moved this thread to the F2 section. The peeps here a really smart and should be able to get you through your problem.
Good luck!
Old Jul 24, 2013 | 02:00 PM
Thanks a lot! I sure hope so. This is my first cbr, my first bike being a 91 gixxer 750. What a difference!
Old Jul 24, 2013 | 02:22 PM
Artie Rivera's Avatar
just the basic check here. To start the engine you will need both fuel and spark. Now this is just a suggestion as a starting point, due to lack of details.
But it sounds like your battery is fine, just needs a recharge, and your starter works if it's clicking, most likely. next thing in electrical is the coils and spark plugs. make sure your coils are providing spark and the spark plugs are in working condition. A common weak spot on the bike is the recharging system, more specifically the Regulator/Rectifier. There is a sticky in the Tech section on how to test/fix that problem.
Next thing is fuel. make sure there is adequate fuel in the tank. make sure your fuel valve,petcock, is in the right position and not off. Fuel hose or line could be clogged. The petcock could be broken and is not vacuuming fuel from the tank. You could empty the tank and pull the lines and petcock. fuel lines are relatively cheap and the petcock repair kit on ebay is like 20$ US. worst case is the carbs gummed up and your jets are not allowing enough fuel into the system. That usually won't happen unless at some point you let the bike sit for a long period of time with fuel in the tank.
The guys here are very helpful and all the information on the site is really helpful as well. Good luck to you and let us know if there is anything else we can help with.
Art
Old Jul 24, 2013 | 02:32 PM
Everything works just fine. As I said before I can pop the clutch and it'll run great after its started. After itts been sitting for say 15 minutes or so, I have to pop the clutch again to get it started.
Old Jul 24, 2013 | 02:35 PM
74demon's Avatar
Travis, how old is your battery? Have you had it load tested?
Old Jul 24, 2013 | 03:08 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
+1 on the load test... it sounds like your battery is not holding the charge; a load test will determine this.
Old Jul 24, 2013 | 03:45 PM
The battery is about 2 months old. Where can I get a load test done at?
Old Jul 24, 2013 | 04:14 PM
gtcole's Avatar
Welcome Crew
They do them free at your local auto zone or advance
Old Jul 24, 2013 | 07:22 PM
Awesome! Ill probably do that tomorrow then and see where that gets me =) Thanks and keep the shiny side up everyone!
