carb jetting question
Old Oct 5, 2008 | 10:15 AM
nabobblaster's Avatar
Default carb jetting question
i've read on here that the jetting on stock carbs is way to rich for these bikes.I live in south Georgia I have a d&d slip on new honda air filter and new carbs with stock jets.The tip of the pipe will haze a little when you burp the throttle.What I'm asking is is what are you guys running near me to get the best power,not the most.So I can keep it from over heating or fry the pistons.Cause the last time we tested it with the junk carbs a pos vance&hines it made 75.3 hp at 11110 rpm at 10.4 air fuel ratio
Old Oct 5, 2008 | 12:53 PM
cowboy from hell's Avatar
Default RE: carb jetting question
NE FLORIDA:124 mains,papper filter,#40 pilot jet,scorpion slip,fuel screws 1 3/4 turns from bottom. just under 90 rwhp.
Old Oct 6, 2008 | 05:20 AM
closest jet I could get was 126 would that sufficiant?
Old Oct 6, 2008 | 06:56 PM
what kit are u using?
Old Oct 7, 2008 | 05:25 AM
don't have a kit just have a set of jets
Old Oct 7, 2008 | 04:13 PM
well u need the whole kit (needle jet new springs shrouds i.a.) a set of mains will do u no good unless you have the neddles to tune them with. a dynojet (recomended) is only like 116$ BUT FIRST! look under your swing arm and look closely do u see a black can looking thing anywhere?
Old Oct 9, 2008 | 04:43 AM
? black can? don't have nothing on there like that.I know I needed the whole kit was trying to get by for now until I tear it down this spring for a rebuild and fix that dang second gear.
Old Oct 9, 2008 | 04:15 PM
ORIGINAL: nabobblaster
if there was a black can then youd have a CA model cbr which requires a different jet kit. just changing the mains will probly make your bike run worse on average id hold off till u get the whole kit. now whats the deal with 2nd gear?
Old Oct 9, 2008 | 05:11 PM
jumps out of second if your not real easy with the throttle.kinda embaressing when in town.was told do to a bent shift fork
Old Oct 9, 2008 | 05:48 PM
yep sounds right to me.
