Carb cleaning, expensive?
Hello everyone!
I am getting a 1991 Honda cbr 600f2 w/ about 19,000 miles
The bike hasn't been run for at least 3 months, probably a lot longer.
The seller says the carbs are gummed so badly if I start the bike I risk fouling the spark plugs which are new.
How much would a shop charge for cleaning/tuning?
Thank You![/align]
Thank You![/align]
RE: Carb cleaning, expensive?
I don't know, I did mine, myself based on the service manual found here: http://hondatech.info/downloads/Moto/ and the instructions therabbit provided found here: https://cbrforum.com/m_311016/tm.htm
I know that if the carbs were taken apart at least once already or if they are cracked and falling apart, than the o-rings should be replaced. Bikebandit.com sells them for $28 a set. You need one set for each of the 4 carbs.
It might take them about 3 hours to do say at $75/hour your looking at $225+ parts & taxes. I'm only guessing here. I really don't know how long it would take them. I figure, I've pulled mine twice already (had to take apart the jets to clean with a very fine wire). I think I might be able to manage in 3 hours or less. It really depends how bad they are. Many people recommend running seafoam through the system. I'm really inexperienced (first bike had running for about a 2 months) at this, so take my information with a grain of salt
This time of year the shops are starting to slow down. Find one of the part timers not getting a lot of hours and have him do it on the side. I did that a while ago when I had ZERO time to do it myself. I do recomend eventually learning to do it yourself though, if you are going to have the bike for a while it will eventually need it again.
