Can't get my F2 Started after doing some work on it
I have just done the following on my 1993 CBR 600 F2:
Oil and filter change
Air filter change
New plugs
New downpipes
Since Ive done all this, the bike did start up (running really rough though) then died after a little while. Now it won't start and pops a lot (backfires) when trying to start it (this comes from both the header pipe area and the end can). What do you think is causing this? I assumed it was something to do with the plugs not sparking so I took them out and refitted them with no joy. They were quite wet so I'm guessing they might not be sparking properly? They are Denso plugs I bought as part of a 'service kit' from eBay and have checked the codes with the old ones and do appera to be the correct ones. - I assume the plug spacing was correct (they look the same as the old plugs - but I have not idea how much difference minute differences make).
Should I buy a guage for the plugs? Do you think it's something else causing it? - It was running ok before I did all this work :? Oh and I just tightened the plugs up as tight as I could with my fingers and then gave them 1/4 turn with a spanner and then pushed the HT leads back on as best I could, although they almost don't seem secure - quite easy(ish) to pull off.
This is the first time I've done any of this so please don't assume anything, I have simply been working from my Haynes manual - I might be missing the most basic things here lol..
Any help would be absolutly great
Air filter change
New plugs
New downpipes
There's only 1 plug the one side so thats right. As for the other 3, the deepest plug has a lead right near it (a short one so it 'must' be for that plug)...
Ther other two look right, and the leads are each a different length, the the longer going to the further plug, but I can try swapping these around?
