Can you lower the forks?
Old Jan 5, 2009 | 07:18 PM
Quickslick444's Avatar
Default Can you lower the forks?
I'm converting from clip ons to riser/db bars. I was wondering.. once the clipons are actually removed the forks will be sticking out of the triple about 2 inches. Am I pretty much forced to run a 2' riser for the bars or can the forks slide down and if so howww much will it change the front suspension. I just need some info before I order the risers.
Old Jan 7, 2009 | 12:50 AM
elmer's Avatar
Default RE: Can you lower the forks?
It'll change the geometry of the bike some. I'm guessing it would adversely affect handling but if you're doing those kinds of mods, handling probably isn't all that critical.
Old Jan 8, 2009 | 02:40 PM
Rickracer's Avatar
Seems like if they are sticking out that much, it's been lowered that much to begin with, dropping the forks back down till the groove in the top is even with the triple clamp should put it back to stock height.
Old Jan 9, 2009 | 10:21 PM
crazkene13's Avatar
ORIGINAL: Rickracer
The fork tubes actually stick out the top of the triple qiute a bit stock, gives room to clamp the clip ons.
I did this exact mod, used tall risers, renthal bars, 3 custom cables from motion pro, longer ss brake lines.
Make sure when you drill the triple clamp you put some large washers on the underside of the triple so the bolts don't pull through.
The riding position is way better.
Old Jan 10, 2009 | 10:36 AM
elmer's Avatar
Just helping out with the images...
Old Jan 10, 2009 | 10:43 AM
Yes I know how to do the swap lol.. Just wondering if the forks will go down without messing much up.
Old Jan 10, 2009 | 12:12 PM
elmer's Avatar
Like I said before, its going to change how the bike handles. The only real way to find out is to try out what works, and if it doesn't work for you then put it back or sell it.
Old Jan 11, 2009 | 12:30 PM
Sand.Man's Avatar
The bike will turn in much slower, and feel about 300lb's heavier in the corners.
It will be more stable at high speeds, but your cornering will suffer quite a bit.
Get the risers and if anything, raise the forks slightly for a more nimble feeling bike.
Old Jan 11, 2009 | 03:35 PM
ORIGINAL: elmer
Well you originally had a guess. And I do not understand why I would sell it. I was just thinking.. the first two inches of suspension travel.. at least on my f2 can be achieved with a small amount of force. But like you said.. the only way to actually find out is to try.
jfunkRR
Apr 30, 2008 09:23 AM
pinit1
Mar 21, 2007 11:47 PM
