Cam Chain Theory
RE: Cam Chain Theory
JK , you cannot visually inspect the cct for wear . If it is worn , loud pipe or not , you will hear it ! normally when engine is warm and at about 4000rpm . Would suggest that you have a fuel / electrical problem causing your poor running , as I said a cam chain fault will either stop the bike completely or it will run bad all the time if it has skipped 1 tooth .
Jimmer.
Jimmer.
37 mpg ain't that bad . Depends how you ride , I get no more than 36 out of mine now that I am used to it but I know that it is running quite rich , but I ain't going to change anything because it goes well as it is . Worth checking your plugs and ht leads first as it's easier than removing your carbs but it does sound more like a fuel problem though .
Jimmer.
Jimmer.
APE tensioners can be found a number of places, just run a google on it.
The procedure it self is just hard enough I say let a pro do it. One thing you do not mess with is cam timing. Just ask Suzuki about 2001/2002 GSXR's and how many engines they bought back.
If you are worried about your tensioner, put your ear near the right side of the engine head when you cold start it. Listen for a rattling noise. A little for a few seconds is acceptable, as oil pressure comes up. After that.. swap it.
ORIGINAL: wayne_carey
the genunine honda cam chain tensioners are ****, buy a manual tensioner and all you will have to do is tweek it up every service, no big drama.
The right way to make sure you have enough tension on the cam chain with a manual CCT is to take the CAM COVER OFF and feel the tension on the chain,
The main reason the HONDA CCTs fail is 'cause people don't realise the gasket only goes on 1 way, put it on the wrong way & it causes excess oil pressure in the CCT making it fail over time,
most of you with little or no mechanical knowledge are gonna be in this thread again in 12 monthes wanting to know how much or how to change the Cam chain, because they overtightened the CCT, I wish I was wrong and hope you prove me wrong but we'll see in a year.
I dont know, it seems like every CBR from the Hurricanes to F4is had CCT problems. Is also common on 929's and XX's. I know Honda can make good ones, but why they dont'/havent is beyond me. I've heard guys say the CCT for a 599 (Hornet) works on an F3 and is solid. The XX guys use the one off a Japan only X-11 and it's a brick. Why can't we get good ones for these bikes.
Manual tensioners are fine if you follow the directions on adjusting them.
