brakes, brakes, brakes
id try to convert to an f3 setup then go with braided lines and good pads. i use galfer but whatever you like.
alright, i just found a picture of the particular bike im thinking of and i misremembered the size, they arent oversized, but f3 rotors on an f2 would be oversized, suggestions?
and what about steel braided lines, i found these lines but im also assuming you get what you pay for and say a goodridge line or something more expensive be worth the cost.
http://www.motorcycle-superstore.com...0F2-Parts.aspx
upon using the old search function it turns out russell is edelbrock so i assume that theyre good lines
ok what i mean is a direct swap with the forks all you lose is the speedo if your racing you can live without it anyway or get ya a veypor or f4i cluster. the f3 has better forks too.....ive seen some crazy **** like r6 front ends but a f3 is a direct swap and a helluva lot less expensive than the ebc float conversion kit. a f3 rear rim will do ya right too.
