-   CBR 600F2 (https://cbrforum.com/forum/cbr-600f2-16/)
-   -   Brake pedal (https://cbrforum.com/forum/cbr-600f2-16/brake-pedal-142887/)
Migge Oct 27, 2012 05:56 PM
Brake pedal
Well, winter hit Sweden as expected but luckily for me I've found myself a man cave where I can tinker all I want with my bike (had I known anything about bikes). Anyways, since the withdrawal symptoms are far too strong to ignore I've decided to streetfight the bike. The discovery of chipped pieces in the fairing, some scratches and such might have influenced me as well. Not only will I try to wrap the tank (has a small dent in it) with carbon fiber (holographic red or something like that from Composite Envisions) but I will also do some minor styling to the bike, for example changing the brake pedal to something more stylish. Do any of you CBR-gurus know where I might find a decent looking foot brake pedal online? Not thinking OEM exact replacement but something that will fit and look good.
Thanks, y'all!
adrenalnjunky Oct 28, 2012 05:59 PM
SV Racing's adjustable rearsets:
SVRacingParts.com
Migge Oct 29, 2012 02:31 AM
Perfect. Damn, the lack of good retailers here in Sweden combined with my lack of the correct words makes it hard to find things. Rear set, I was not even aware that it could be called that...
Thanks a lot, adrenalnjunky!
adrenalnjunky Oct 29, 2012 01:32 PM
dig around on Ebay too - several companies used to make rearsets for F2/F3's but most have stopped production - Woodcraft & Yoshimura were 2 bigger names.
I've heard that F4/F4i rearsets will fit our bikes, but I can't verify that myself.
JNSRacing Oct 29, 2012 01:56 PM
Migge, Pro-Tek also still makes rear sets for the F2 - it locates the pegs the typical 1" up and 1" back.
This particular unit is non-adjustable - if you want to see what it looks like on the F2, check my build thread.
They were unavailable for a while, then several places got more in. I got mine from motorcycle-superstore.com
Oh, and, vote for me for October ROTM... just two days left! :D
Migge Oct 29, 2012 06:16 PM
Great news. Will surely look at your magnificent bike (again... Drooling...). Since I'll fight mine, I'm not too sure about giving it an even sportier stance. But I'll check it out! And JNS, you got my vote a long time ago... :)
JNSRacing Oct 30, 2012 08:30 AM
Originally Posted by Migge (Post 1200195)
...Since I'll fight mine, I'm not too sure about giving it an even sportier stance...
With just about all aftermarket rearsets, in addition to being lighter than stock, the main purpose is to give you more ground clearance, and I can only assume the Woodcraft units will raise the pegs up and back as well.
Even though you're going streetfighter with the bike, I assume you still want to be able to corner hard without dragging stuff! I can say that the 1" up and back is not so extreme that it makes riding uncomfortable, if anything, I need more, as I still drag pegs here and there, at higher lean angles - I'm just a hair under 6', and like I said, it doesn't cramp me at all, or feel strange.
...And JNS, you got my vote a long time ago... :)
Ahhhh, I see, then you, sir, are one cool cat!! :icon_pimp:
adrenalnjunky Oct 30, 2012 09:54 AM
This thread reminds me, I bought a set of rearset riser adapters a while back that moved the stockers up and back - I couldn't install them due to my mid pipe hitting.
I had forgotten about those things. I need to pull my exhaust off the header and install the rearsets, then see if I can make it work, or where I need my midpipe "massaged" some.
JNSRacing Oct 30, 2012 10:23 AM
I had forgotten about those things...
Ahhh, Junky, do tell! I am seeking some risers, for additional clearance - where did you buy them, etc., etc., etc.??
adrenalnjunky Oct 30, 2012 11:19 AM
IIRC I bought mine off ebay. F4/F4i rearset risers were reported to work with our bikes, so that's what i bought. I know they bolt up properly, like I said I was just having an interference issue with my midpipe - but I'm pretty sure it is the midpipe's fault, not the risers.
This thread is where I got the info:
https://cbrforum.com/forum/cbr-600f2...-103153/page2/
The parts are available on ebay still - but turns out they're just the SVRacing F4 risers: SVRacingParts.com
