Brake pedal
Well, winter hit Sweden as expected but luckily for me I've found myself a man cave where I can tinker all I want with my bike (had I known anything about bikes). Anyways, since the withdrawal symptoms are far too strong to ignore I've decided to streetfight the bike. The discovery of chipped pieces in the fairing, some scratches and such might have influenced me as well. Not only will I try to wrap the tank (has a small dent in it) with carbon fiber (holographic red or something like that from Composite Envisions) but I will also do some minor styling to the bike, for example changing the brake pedal to something more stylish. Do any of you CBR-gurus know where I might find a decent looking foot brake pedal online? Not thinking OEM exact replacement but something that will fit and look good.
Thanks, y'all!
Thanks, y'all!
Perfect. Damn, the lack of good retailers here in Sweden combined with my lack of the correct words makes it hard to find things. Rear set, I was not even aware that it could be called that...
Thanks a lot, adrenalnjunky!
dig around on Ebay too - several companies used to make rearsets for F2/F3's but most have stopped production - Woodcraft & Yoshimura were 2 bigger names.
I've heard that F4/F4i rearsets will fit our bikes, but I can't verify that myself.
Migge, Pro-Tek also still makes rear sets for the F2 - it locates the pegs the typical 1" up and 1" back.
This particular unit is non-adjustable - if you want to see what it looks like on the F2, check my build thread.
They were unavailable for a while, then several places got more in. I got mine from motorcycle-superstore.com
Oh, and, vote for me for October ROTM... just two days left!
Great news. Will surely look at your magnificent bike (again... Drooling...). Since I'll fight mine, I'm not too sure about giving it an even sportier stance. But I'll check it out! And JNS, you got my vote a long time ago...
Even though you're going streetfighter with the bike, I assume you still want to be able to corner hard without dragging stuff! I can say that the 1" up and back is not so extreme that it makes riding uncomfortable, if anything, I need more, as I still drag pegs here and there, at higher lean angles - I'm just a hair under 6', and like I said, it doesn't cramp me at all, or feel strange.
Ahhhh, I see, then you, sir, are one cool cat!!
This thread reminds me, I bought a set of rearset riser adapters a while back that moved the stockers up and back - I couldn't install them due to my mid pipe hitting.
I had forgotten about those things. I need to pull my exhaust off the header and install the rearsets, then see if I can make it work, or where I need my midpipe "massaged" some.
Ahhh, Junky, do tell! I am seeking some risers, for additional clearance - where did you buy them, etc., etc., etc.??
This thread is where I got the info:
https://cbrforum.com/forum/cbr-600f2...-103153/page2/
The parts are available on ebay still - but turns out they're just the SVRacing F4 risers: SVRacingParts.com
