bike wont start
removed all jets except the ones said and used compressed air for the others', not sure if i got the wires to coils right way round could ihave done any damage if i have . battery seems ok , got it to start on easy start only for seconds though ,and still backs fires. checked petcock petrol used to run out before now it dosent , manual said its vacume engine should pull petrol through.spent hours checking everthing , checking all wiring connectors and grounds now.
ok so im new to this site and joined because i have a problem with my bike as well i have a 1999cbr and it ran when i put it away in mid september , this after noon i tryed to start it . . . it had a dead battery so the bone head i am tryed to jump it with the battery charger on boost . . . so needless to say the bike did not start and i now have no spark , i checked all the fuses and now i am on to checking the stator but i do not know what the resistence should be with the multimeter . so if any one can help that would be great . thanks again
He's right. Make sure you can see the light through the hole. That gas gunk that forms in the jets can get hard as a rock. You need some jet cleaners or the wire from a garbage bag tie wrap. Make sure to twist it it as you push it through.
Removd carbs spent 4hours cleaning all jets like you said.cleaned tank out but it was clean .checked rubbers in petrol tap . put it all back together ,checked plugs for spark fine . moment of truth not a glimmer where do i go from here didnt even try to fire and yes the kill switch was on run.
The (left)other coil has Black/White & Blue/Yellow(Solid Blue, Yellow trace) these go to #2 & #3 Cyl.
