bike dies
ok here are some problems with my bike that i encountered,
the clutch fine adjustment cable screw is stripped and the cluster is rethreaded, when i adjust the friction point and ride my friciton point moves all over the place so im thinking thats whats causing all of the problems below: -bike shifts in to neutral on its own -bike dies at stop lights and doesnt start up, i put her in first press run and it just cranks, put her in neutral same thing happens (i hope this is not an electrical problem) -clutch slips it should just be the the screw and cluster hole right? i have a 1994 f2 thanks |
RE: bike dies
I think the F2s have to be in neutral to start, even if you have the clutch lever pulled. You might want to get a new clutch cable and adjusting hardware for the left-side perch. At least that's an inexpensive place to start.
RE: bike dies
F2's do NOT have to be in neutral to start. The transmission can be in gear, but clutch lever must be pulled in. Sounds like you need a new cable and adjusting hardware, as mentioned above.
RE: bike dies
I stand corrected, Rocky.
RE: bike dies
Maybe somthing in the kickstand sensor or somthing. Ive noticed that If I forgeet to put tehe kickstand up when I put her in gear she dies. Maybe a sensor is going bad in your kickstand???? Just an option...
RE: bike dies
yea it could be a sensor problem...when i put her in first she dies thanks
what could be the problem when coming to a stop the bike just dies? low gas? |
RE: bike dies
how many fuel lines are supposed to be connected to the tank?
where is the idle adjustment? thanks |
