Better pic of the F2
can you believe this bike is a 91 model with 34,xxx miles on it and still looks this good? thats all still the factory paint.
[IMG]local://upfiles/5193/6C4CE71728FE4CE0921C6F5ECF37B17E.jpg[/IMG]
nice ride bought mine last year with 5400 miles on it. It now has 10,000 on it and I love the old school bike. I did the -1/+2 earlier this year. It dropped the top speed to about 135 @ the rev limiter but it sur does get there in a hurry!!!
Maxim chain wax. i clean the chain with WD-40, wipe it off and let it dry. then i ride it to heartup the chain and wipe it down with a rag again to get any excess WD-40 off of it. then spray on the chain wax and roll the wheel backward while holding a rag around the chain by the bottom of the rear sprocket to remove the excess. just make sure you roll it backward so the rag and your fingers dont get pulled into the chain and sprocket mesh. the biggest factor with the lube flinging onto your wheels is applying too much lube. wipe off the excess after spraying it on and the wax will only be where its needed, on the moving parts of the chain.
