Bent shifter?
Old Jul 19, 2012 | 01:51 AM
Optimus_Prime's Avatar
Default Bent shifter?
My shift lever has a slight bend in it and I've always wondered if that's normal or if it should be straight. Check out the picture and let me know if it looks normal or not.
I've been riding it for years like this but decided I might sort it out if it shouldn't have a bend like that.
Thanks in advance for opinions.
Old Jul 19, 2012 | 02:04 AM
subyman1440's Avatar
Don't think it's supposed to be like that. Last time I checked my shift lever, it was completely straight...I'm sure if I check again, it'll be bent LOL
Old Jul 19, 2012 | 05:35 AM
RedBaron's Avatar
Mine is a little bent but not as much..
Old Jul 19, 2012 | 03:02 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
It IS supposed to be straight, but that looks usable, anyway. If you find it's too far inside for comfortable shifts, you can take a claw hammer, preferrably a big framing hammer, and use the claw part that pulls nails, to orient around the shifter pedal arm, and carefull pry it out straight - I had to do that after my accident a couple of years back - worked like a charm.
Old Jul 19, 2012 | 05:04 PM
Thanks for the feedback. It's part of owning a used bike I guess, getting more familiar with it over time and discovering all the little 'customizations' the previous owner did to the bike. I figured it had been dropped at some point and the shifter got a little bent. I'll try and straighten it out a bit and see if it makes shifting a tad easier.
Old Jul 19, 2012 | 08:45 PM
Wranghondo's Avatar
You oughta see MINE! Looks like a pretzel!
Old Jul 19, 2012 | 11:39 PM
JankCibberf2's Avatar
Mines bent te same if not worse. It's just because po dropped our bikes. No big deal
Old Jul 20, 2012 | 07:30 AM
Wranghondo's Avatar
Yep! Both of my pegs are slanted to the rear at a pretty good angle too.Name:  cbr2.jpg
Size:  8.0 KBI've considered making a jig that I can bolt the peg mounts to and then put in a vice and bend them back straight.
Old Jul 20, 2012 | 08:54 AM
And bent *** pegs are not helpful during wheelie time!
Old Jul 20, 2012 | 06:04 PM
Wranghondo's Avatar
I'm sure I'll have new/fixed pegs before I start doing wheelies. Wheelies are pretty low on my list of skills to master.
