Battery Not Holding Charge
Yesterday i had to charge the beast and for some reason it would hold charge to stay and go but when i would turn it off and try to start it, it wouldnt start now correct me if im wrong but either i think 1. The battery is no good 2.A fuse has gone sour if so which one to look for Please help me
probably not fuse bc there are only 4 fuses and there all components you would notice if they went out (like gauges). I had the same problem, for some reason i had three wires arc and blow, and also the plug that goes into the voltage regulator burnt out. replaced and/or fixed them and i was back up and running, If its not simple and easy to find i reccomend leaving electrical problems to professionals.
