Anybody built a 637cc F2?
Old 11-29-2011 | 04:46 PM
underground-mpyre's Avatar
Pmb- Have you changed your cams? I do not know what BHP translates to WHP, seems low.
  #42
Old 11-30-2011 | 03:20 AM
pmb5's Avatar
sorry, that's 93hp SAE at the wheel.
It's got UK spec cams, it did have CA spec cams before. The Dyno does read very low (Dynapro), as I said a standard bike (newly rebuilt) with a full system and race filter would make about 90 SAE hp on this dyno.
I do have some supersport cams, but dont want to loose my midrange at the moment.
  #43
Old 11-30-2011 | 02:53 PM
Project96's Avatar
Put 900 pistons & sleeves in it & call it a day... Makes a six-ninty something with the increased bore & same stroke as the F2/F3.
  #44
Old 11-30-2011 | 04:08 PM
pmb5's Avatar
I can't go over 650cc. Breaks the rules of the class I wana race it in.
  #45
Old 11-30-2011 | 07:12 PM
Wow, somethings wrong with those numbers if stock is 87WHP and with my mods I am at least above 93whp.
  #46
Old 12-01-2011 | 12:10 PM
pmb5's Avatar
nope, it's a low reading dyno. They are very good, but give lower results than most.
Dyna Pro Dynamometers Ltd
  #47
Old 12-01-2011 | 01:21 PM
Considering most 637's average around 108-113whp with tuning, that is low. I am not trying to insult you any 'PMB', but something isn't adding up.
  #48
Old 12-03-2011 | 03:20 AM
pmb5's Avatar
I'm not offended, and now I re-read my reply, it's pretty blunt, sorry for that, I replied from my phone. These dyno's read very low compared to say dynojet or fuchs. On one of those I'd be making around 105hp. The Dyno guy didnt do the tuning so he has no reason to fudge the numbers (or my mind)
I'm back at the Dyno on Wednesday and it'll be much colder this time so we'll see, if i can i'll scan the printout and upload it. I don't really want much more than 95hp, because I'll need to start adding lead to the bike to make it heavier.
  #49
Old 12-03-2011 | 04:34 PM
PMB, I will trade you blocks then! LOL
  #50
Old 02-01-2012 | 01:04 AM
kingyeddi's Avatar
I rebuilt an F2 with a 637cc kit, F3 carb/pump and ram air conversion, i blogged it too:
CBR 600 F2 Thunderbike
some of the older pic links are broken (like the 5.5 rear wheel conversion), if there is enough interest i'll fix them
****ING SEXXX!!! That is my kinda f2/3 there :-D Good work
Originally Posted by underground-mpyre
Well I know the F4i Intake cams will work on the intake side and swapping the F2 intake cam to the exhaust is what some do for a cheap fix for racing cams.
Never knew this!!
Originally Posted by coalminer frank
Somewhere on the FireBlade site they talked about +2mm(637cc), the guy that did it said it was alot of work, alot of money, and not very much power increase. Of course if you did the cams, head, lightened crank, to compliment the displacement increasement it would probly be a healthy increase in power. And a major increased $$$$$$$$$$. Also they mentioned something about cbr 900 pistons in the f2 engine for around almost 700cc's. With no overheating issues. Had to press out the sleeves bore is for bigger sleeves etc. Sounds like alot of money, work, etc when a newer 600 would be more reasonable and reliable. But an old f2 built to the max would be awesome.lol
or this!! Got links to 900 piston builds?
Quick Reply: Anybody built a 637cc F2?
