Any ideas for a replacement petcock other than a new Honda one @ $185??
Old Jul 26, 2008 | 10:08 AM
Rickracer's Avatar
Default Any ideas for a replacement petcock other than a new Honda one @ $185??
I've taken the stock one apart and tightened it up as much as possible, the the seals are just shot. Anybody got any ideas for a replacement other than a new one from Honda? Any such thing as an aftermarket replacement, even a universal one? My bike fuel fouls a plug every few days, and that really bugs me, I know it's not good for the motor to have that much fuel sitting in a cylinder.
Old Jul 26, 2008 | 10:50 AM
Guambomber's Avatar
Default RE: Any ideas for a replacement petcock other than a new Honda one @ $185??
i know its a pain, but heres what i did. i installed a small inline shutoff valve between the stock petcock and the carbs. i reach in through the hole in the fairing where the idle adjuster is at to turn it on and off. its a pain, but better than pulling plugs all the time!!!
Old Jul 26, 2008 | 07:03 PM
SJN's Avatar
SJN
Size:  18.1 KBOr buy new seals...
Old Jul 26, 2008 | 07:15 PM
Rickracer's Avatar
Mine doesn't have that, (the vacuum part, I thinkthe whole thingmay have been replaced by a unit from an F3 at some point in time),and Honda says there are no seals or rebuild kit available, only a complete unit. If I could buy the rubber part, I'm sure I could fix it....
Old Jul 28, 2008 | 12:18 PM
stretchedf2's Avatar
try going to WWW.BIKEBANDIT.COM you can buy replacement parts for the petcock assembly there.... the dealerships didn't get the name Stealership for nothing ya know..lol
Old Jul 28, 2008 | 01:33 PM
Rickracer's Avatar
I've been there, and all they show is complete assemblies. The petcock that's on mine now has a steel plate riveted over a rubber "gasket", and the "gasket" has raised edges thatseal to the steel ball that's controlled by the valve handle. I'm pretty sure nobody will make that as a service part, in fact, I'm pretty sure you're not supposed to be able to take the petcock apart, but I did. I drilled right through the swaged metal tips that hold the whole thing together and tapped it for some small machine screws.
Old Jul 28, 2008 | 05:42 PM
ggrahn's Avatar
Pingle makes a valve. $125. No more vacuum hook ups. I do turn it completely off every time I am done riding.
Old Jul 29, 2008 | 06:33 AM
Rickracer's Avatar
Now that's what I'm talking about, thanks. Quite a range of prices out there for the same part, anybody seen them on eBay?
Old Jul 29, 2008 | 02:04 PM
drpitlo's Avatar
http://www.carolinacycle.com/fiche_select.asp
Old Jul 29, 2008 | 07:47 PM
Rickracer's Avatar
They have any Pingle fuel valves?
