Another gusher...
Old Aug 25, 2007 | 06:07 AM
410600f2's Avatar
Default Another gusher...
...started bike and noticed fuel was draining on ground beneath it, after further investigation I found it was pouring out of two tubes that look like they come from the airbox/carb area. What is going on, and how do I correct the problem?
Old Aug 25, 2007 | 12:19 PM
1idiot's Avatar
Default RE: Another gusher...
If you open the gas cap, does it seem likethe tank ispressurized? One time when I putmy tank back on, I pinched the (smaller) breather tube off the bottom of the tank by accident. When I started the bike it did the same thing; built up pressure in the tank and pushed fuel out of the (larger) drain tube.
Old Aug 25, 2007 | 10:31 PM
felk27t's Avatar
did you figure your petcock out? is that the problem?
Old Aug 26, 2007 | 07:53 AM
410600f2's Avatar
I dont think its a tank or petcock problem because I could see exactly where the fuel was leaking from. I have two tubes that exit airbox/carb area ,cross over each other and end around the fuel line area. Fuel was pouring from the tubes a few seconds after starting ( first start early morning).
After that I came inside and asked around here for some help and after about ten minutes went outside and tried again.... no leak this time! I'm not a mechanic so what I'm about to say could not make much sense but is it possible I flooded the engine and that was excess fuel draining?
Old Aug 26, 2007 | 09:40 AM
felk27t's Avatar
possibly...when was the last time you cleaned the carbs???
Old Aug 26, 2007 | 10:11 AM
410600f2's Avatar
March/April for carb cleaning. Just had the bike jetted could that be causing an issue
Old Aug 26, 2007 | 10:14 AM
felk27t's Avatar
got me on that one....when does b&e get back from racing???? or is he???
Old Sep 13, 2007 | 05:17 AM
eweppley's Avatar
Your floats might just be stuck. Had this happen to me a couple times. If you don't want to tear them apart and clean them just yet, try tapping on the float bowls with something that won't damage them (screwdriver handle, broomstick, etc.). They're a pain to get at, but you can do it by only taking a couple of fairing pieces off.
Old Sep 13, 2007 | 11:55 AM
jahnaboi's Avatar
I think the clamps that holds the lines you speak of might just be lose a little to the point fuel leaks out. That's my 2cents
Old Sep 3, 2009 | 08:53 AM
flyboy1011's Avatar
I'm having the same problem....how do I get to the float bowls to tap on them, and is it as simple as just "tapping" them or what all should i do? Plannin on trying to do this after work tonight...thanks.
