Aftermarlet F2 plastics?????????
ORIGINAL: cbrjeeper
Aftermarket? You mean different from OEM? The search button is your friend.
Tylor
Tylor
Wow what a common answer, thank you so much jeeper but I have tried to search and have come up empty.
You didn't answer the question. Aftermarket as in not the same as factory?
Sorry if I seemed negative, it's just that alot of newbies to the board come on and just start asking questions without searching. I'll look around some and give ya links.
If you're looking for OEM stuff, check ebay
If you want race or custom skins, these guys have afew
airtech
Tylor
airtech
Tylor
ORIGINAL: cbrjeeper
airtech
Tylor
airtech
Tylor
So is it safe to wash my bike with water??? I understand man. I am trying to replace my whole front upper cowling and one left rear fairing as well as a right repair window thingy. As far as I can find I have to buy the whole unit intact but that is not what I want. I will most likely go with the front upper via Ebay when the price is right (fluctuates) but I can not find single peice fairings (not OEM) anywhere that ships to Canada. I am also considering rebuilding an f3 motor to slam into her in the future but will do it to the max IE: port, polish, carbs, exhaust etc etc. I have done this with my car but am very tempted to try it with my bike. Seems very hard to get templates and proper info on a F2 witch puzzles me since it's an older bike and one would think information would be overloaded. In anycase thanks Jeeper I would appreciate any input you may have
Where are you from CROMAG?
if your from the UK you'll be able to get the panels from Honda easy, just give em your chassis number
and the paint code which is on a sticker, near the rectifier
they are pricy but they come ready to fit in the original color.
the front cowl upper comes in 3 or 4 parts Left, center top, &bottom, Right. I know i just got a left top cowl.
cost £201 with vat but if you look at it this way, if you buy an aftermarket 1 you still have to get it painted then graphic s it comes to more than the Honda part.
hope this helped
hope this helped
ORIGINAL: mikequinn
hope this helped
hope this helped
Would people recommend buying (if one was to buy off of ebay) the solid upper cowl with or without everything cut out? Also for those who have purchased them are they good quality? I just worry about them not lining up correctly, then I would have to drill out extra holes, but then I am worried about how good of a job I could do cutting out the headlight.
Thanks,
Dan
Thanks,
Dan
I would try to buy a cowl that is perfectly cut out and ready to bolt on.
All you should have to do is paint it.
Our bikes are so old it's hard to find someone who knows how to make it like the real thing if it needs to be cut.
